Tools
Geometry scanning
- Import image set.
3D Mesh modeling
Importing the point clouds
Geometry modeling
- Install BlenderBIM Add-on
BIM modeling
- Opt 1) Import a mesh file.
- Opt 2) Import a IFC file.
BIM modeling
- Open Draft Workbench.
- Arrange the Shape2DView projections in the 3D scene. Once you are done, you will not be able to move these projections anymore.
2D CAD documentation
- Create a new FC file.
- Alternative you can import the Shape2DView objects using App:Link option.
- Open Draft workbench.
- Save the file.
- Open TechDraw workbench
- Create a new page.
- Select a Shape2DView object or a group of them.
- Press TechDraw Insert View command
