Tools
As a basic requirement for this tutorial, it is necessary to have a medium level of knowledge about these tools, used in this workflow.
Geometry scanning
- Import image set.
3D Mesh modeling
Importing the point clouds
Geometry modeling
- Install BlenderBIM Add-on
BIM modeling
- Opt 1) Import a mesh file.
- Opt 2) Import a IFC file.
BIM modeling
- For each Arch Building Part, create an Arch Section Plane.
- Save this file. This file will contain basically only the 3D geometries.
2D CAD documentation
2D documentation
