Tools
Geometry scanning
- Import image set.
3D Mesh modeling
Importing the point clouds
Geometry modeling
- Install BlenderBIM Add-on
BIM modeling
BIM model with FreeCAD (using as reference the mesh from Blender). Once I got a good mesh volume, I exported a stl file to FreeCAD to recreate the main walls and windows with the Arch Workbench.
Opt 1) Import a mesh file. Set and scale the mesh with Mesh Design workbench. Opt 2) Import a IFC file. FreeCAD can open IFC2x3 or IFC4 based files. See Arch IFC. Check the FreeCAD Preference for additional options of IFC import/export feature.
2D CAD documentation
2D documentation
