Free software libraries for AEC software development
IFC-Commenter | A simple script for creating a commented-out hiearchy in an IFC file. | MIT | |
LibreDWG | GNU LibreDWG is a free C library to handle DWG files. It aims to be a free replacement for the OpenDWG libraries. DWG is the native file format of AutoCAD and a number of other CAD packages. | GPL-3.0 |
OpenCascade | OpenCascade (Community Edition) is a C++ 3D modeling library. It can be used to develop CAD/CAM softwares, for instance FreeCAD or IfcOpenShell. | LGPL-2.1 | |
xeogl | xeogl is an open source JavaScript library from xeolabs for 3D model visualization on WebGL. It gives you tools to create interactive 3D worlds in your browser. Load models from formats like glTF or OBJ, or generate them programmatically. | MIT |
