MicroMVDs for exchange requirements/Geolocation MicroMVD
Feature: Geolocation In order to query data in real world coordinates As a recipient expecting to integrate BIM and GIS datasets Geolocation data must be stored correctly in received files Scenario: Receiving a file * The IFC file "{file}" must be provided * IFC data must use the {schema} schema Scenario: Geometry is georeferenced to a coordinate reference system * There must be at least one IfcSite element * The project must have coordinate reference system data * The name of the CRS must be {coordinate_reference_name} * The description of the CRS must be {value} * The geodetic datum must be {coordinate_reference_name} * The vertical datum must be {coordinate_reference_name} * The map projection must be {coordinate_reference_name} * The map zone must be {coordinate_reference_name} * The map unit must be {unit} Scenario: Local coordinate systems are specified relative to a global system * The project must have coordinate transformations to convert from local to global coordinates * The eastings of the model must be offset by {number} to derive its global coordinates * The northings of the model must be offset by {number} to derive its global coordinates * The height of the model must be offset by {number} to derive its global coordinates * The model must be rotated clockwise by {number} to derive its global coordinates * The model must be scaled along the horizontal axis by {number} to derive its global coordinates Scenario: Global coordinates of the project origin are provided for convenient reference * The site {guid} has a longitude of {number} * The site {guid} has a latitude of {number} * The site {guid} has an elevation of {number}
{file}
{schema}
{value}
{unit}
{number}
{guid}
Software guides
Import | Export | ||||
ArchiCAD | ||||
FreeCAD | ||||
