MicroMVDs for exchange requirements/Grids MicroMVD
Revision as of 23:26, 22 June 2021 by Moult (talk | contribs) (Created page with "The following MicroMVD vocabulary can be used to ensure IFC data includes grids. <pre> Feature: Grids In order to locate object...")
Feature: Grids
In order to locate objects
For all model coordinators and recipients of the final built environment
Grids must be present
Scenario: Ensure that grids are present
 * There are grids
 * A "{shape}" grid with the name "{name}" exists with the correct number of axes
Variable Example Description
{shape} rectangular The shape of the grid, chosen from "rectangular", "radial", "triangular", or "irregular".
{name} A The name of a grid, typically "A" or "B"
