FreeCAD
- License: GPL-2.0-only
- Website: https://www.freecadweb.org
- Wiki: https://wiki.freecadweb.org/
- Source: https://github.com/FreeCAD/FreeCAD
- Donate: https://wiki.freecadweb.org/Donate
External pages
- FreeCAD BIM migration guide
- The BIM Workbench
