Tools
Blender (v2.8)
FreeCAD (v0.19)
Geometry scanning
- Import image set.
3D Mesh modeling
Importing the point clouds
Geometry modeling
- Install BlenderBIM Add-on
BIM modeling
- Opt 1) Import a mesh file.
- Opt 2) Import a IFC file.
BIM modeling
- Open Draft Workbench.
2D CAD documentation
- Create a new FC file.
- Open Draft workbench.
- Save the file.
- Open TechDraw workbench
- Data/ Override Style = true
Export PDF files
