Tools
Blender (v2.8)
FreeCAD (v0.19)
Geometry scanning
- Import image set.
3D Mesh modeling
Importing the point clouds
Geometry modeling
- Install BlenderBIM Add-on
BIM modeling
- Opt 1) Import a mesh file.
- Opt 2) Import a IFC file.
BIM modeling
- Open Draft Workbench.
2D CAD documentation
- Create a new FC file.
- Open Draft workbench.
- Save the file.
- Open TechDraw workbench
- Data/ Override Style = true
TD InsertView | for Shape2DView | Allow to apply hatches on plans and sections areas |
TD DraftView | for Draft Layers | Allow to apply line styles and other properties on group of objects |
TD DraftView | for Draft objects | Allow to apply line styles and other properties on individual objects |
