Tools
Blender (v2.8)
FreeCAD (v0.19)
Geometry scanning
- Import image set.
3D Mesh modeling
Importing the point clouds
Geometry modeling
- Install BlenderBIM Add-on
BIM modeling
- Opt 1) Import a mesh file.
- Opt 2) Import a IFC file.
BIM modeling
- Open Draft Workbench.
- Arrange the Shape2DView projections in the 3D scene. Once you are done, you will not be able to move these projections anymore.
2D CAD documentation
- Create a new FC file.
- Open Draft workbench.
- Save the file.
- Open TechDraw workbench
- Create a new page (define format and scale).
- Select a Shape2DView object or a group of them.
- Select Draft objects (lines, symbols)-Press TDIV command
- Select the Draft Layer of dimensions.
- For lines with style, select their Draft Layer. Press TD DraftView and setup the property:
- Data: Line Style = 5,2,0,5,2 (or something similar).
- Data: Override Style = true
- Create a TD Clip and place all the views inside.
