Tools
Geometry scanning
- Import image set.
3D Mesh modeling
Importing the point clouds
Geometry modeling
- Install BlenderBIM Add-on
BIM modeling
- Opt 1) Import a mesh file.
- Opt 2) Import a IFC file.
BIM modeling
- For each Arch Building Part, create Arch Section Planes.
- For each Arch Section Planes, create Draft Shape2DView objects (elevations, plans, sections, etc). You can edit the labels of these Shape2DView to refer names.
- Create all the Shape2DView, considering the necessary 2D views for the CAD documentation.
- Save this file. This file will contain basically only the 3D geometries and the plain Shape2DView projections.
2D CAD documentation
2D documentation
