MicroMVDs for exchange requirements/Element classes MicroMVD
Feature: Element classes In order to correctly identify objects As any interested stakeholder filtering objects for a particular purpose All IFC elements must belong to the appropriate IFC class Scenario: Receiving a file * The IFC file "{file}" must be provided * IFC data must use the {schema} schema Scenario: Ensure all IFC type elements use the correct IFC class * The element {guid} is an {ifc_class} * The element {guid} is an {ifc_class} only * The element {guid} is further defined as a {predefined_type} * The element {guid} should not exist because {reason}
{file}
{schema}
{guid}
{ifc_class}
{predefined_type}
{reason}
Software guides
Import | Export | ||||
FreeCAD | ||||
Revit | Revit 2020.2 IFC 8/5/2020 | Revit 2020.2 IFC 8/5/2020 | For import, opening an IFC does not retain any element class information. Linking IFCs do retain this information. For export, some Revit family categories have restrictions on which element classes they can be exported to, and the user cannot override it. |
