The OpenBIM Pledge
Revision as of 23:13, 5 April 2025 by Moult (talk | contribs)
Tier 0
Tier 1
Tier 2
Tier 3
Tier 4
Tier 5
... more to come.
Tier 6
... more to come.
But why?
For those new to this concept, "OpenBIM" is a term meaning an international open data standard for BIM. The benefits of using open data standards regardless of industry are already elucidated in many sources online. That said, here's a summary of key technical features having practical implications on your project workflows and company digital strategy. As our in-house digital capabilities increase over time, the benefit of having the flexibility and ability to manipulate data using standards multiplies.
  • Given an OpenBIM dataset, you can view/edit it with any software (or build your own) with no need for subscriptions, terms of use restrictions, or limited to APIs. This has both a cost and capability implication on digital strategies. Primarily, it means that your digital strategy is no longer vendor-centric and limited to "what tool X lets me do", and can instead be data-centric and optimised for business needs.
  • You can use OpenBIM datasets on any platform (Windows, Mac, Linux, server, web, desktop, phone). You may serialise it in any form you wish (text, database, binary, JSON, XML, SQL, HDF5, TTL) or pair it with any development language (C++, C#, Python, Javascript, Perl, Pascal). No matter what your IT technology stack, open data standards can integrate. This opens up flexibility and future proofing for changing technologies, increased hiring pools, and external system integration.
  • OpenBIM datasets won't expire or corrupt even in 50 years with no maintenance at all. As a case in point, IGES and STEP (which IFC has heavily evolved from) are still available from 40 years ago. This makes it useful for archival, data lakes, and for those managing large real estate portfolios where the cost and risk of proprietary version upgrades and corruption are high.
  • Information is stored in standardised locations. This is perhaps the biggest advantage that most people are missing out on. OpenBIM defines a data dictionary with standardised names and data types for most common properties. For example, storing the "wall type name" or "fire rating" of a wall, is stored in a different property name, data type, or data schema in every single software, company, or project. (e.g. Revit users will inconsistently use "Type Mark", "Keynote", "Comment", "Description", "Type Name" to name or label an object). Data inconsistency means that you cannot automate or audit systems without mapping data on every job. You may have a company standard that recognises this problem and mitigates the issue, but is really reinventing the wheel where international data dictionaries already exist. Imagine your current difficulty (i.e. you have to create a bespoke filter or query) asking simple questions like "where is the fire rating of a wall stored" or "how do I find how much reinforcement is inside my beams" or "how do I isolate all precast concrete elements" or "how does the critical path differ between planned and actual work schedules"? The answers are standardised with OpenBIM and will work with any project, even if it's in French or Japanese and you don't speak the language.
  • All projects are interdisciplinary. Despite this, most of us still work with siloed discipline datasets (i.e. one dataset for architectural models, another for energy analytical models, another for cost schedules, etc). In OpenBIM, this limitation falls away and the data schema can store both data and inter-relationships across many disciplines (structural analysis, energy, construction sequencing, asset management and inventories, cost, work orders, etc). This is akin to that "holy grail" stuff promised about BIM that people never thought was possible, because their vendor-centric digital capabilities still revolved around tool X and tool Y limited to specific capabilities for specific disciplines. For example, most people don't know that IFC can handle "smart building" stuff like sensors connected to event triggers and procedures.
  • There's a lot that IFC can do that proprietary systems cannot (and vice versa, more on that later), but one critical one to single out is that IFC can actually be georeferenced. Most BIM data have no standardised way to store coordinate data (e.g. Revit can store coordinates, but cannot store the coordinate system) or are unitless (DWG/DXF).
  • OpenBIM data is highly "semantic" and "object oriented". What this means is that the data is more meaningful than a name-value pair attached to an object. For example, if the material of an object was stored as a property named "Material", that means you need to know the keyword "Material", and you're limited to storing a single value for the material. In contrast, if materials were a semantic object, then you don't need to know the keyword "Material" beforehand, and you can store lots of meta-information about the material (colour, compressive strength of concrete, reinforcement density, steel grade, young's modulus, etc), as well as have N:N relationships (e.g. composite materials). This means that when you build digital systems and workflows, your ways of creating and analysing data can be more sophisticated. Other examples include hierarchical classifications, document URI references, proper distinctions between visual style and materials, element connectivity, etc.
But why not?
  • If you need to upskill to learn about OpenBIM, organisations like buildingSMART, OSArch, and consultancies who have signed the OpenBIM pledge are a great place to start. There are a variety of channels including structured learning courses, personal consultancy, or self-guided learning including live chats or long-form forums.
  • As OpenBIM is international, it lacks country or government specific data standards. The best thing to do is to reach out to your local buildingSMART chapter to develop, maintain, and provide local data dictionaries. Help can be provided from the above channels.
  • As OpenBIM focuses on semantics, and is agnostic of how those semantics are produced, you need to be aware that the means of delivery is deliberately out of scope. It is still valuable to request "the authoring format" (sometimes called the "native format", this is the format where data is authored). You should not mandate a particular authoring format (see Tier 1), as that would limit the best tool being used for the job. As digital authoring gets more sophisticated, authoring formats may be a combination, including spreadsheets, scripts, and tools (Revit, ArchiCAD, etc). Note that IFC itself can be the native authoring format, in which case there is nothing further to request.
  • There are current known limitations or unknown in OpenBIM standards regarding 2D documentation (drawings, schedules, etc), lifecycle analysis, parametric task/cost to product associations, among others. This is an area of active development and research. That said, this type of stuff is around the more advanced tiers so there's plenty to catch up on in the meantime.
Signatories
Currently collecting interest.
