MicroMVDs for exchange requirements/Geometric detail MicroMVD
Revision as of 11:22, 28 July 2022 by Duncan (talk | contribs) (Duncan moved page MicroMVDs for exchange requirements/MicroMVDs for exchange requirements/Geometric detail MicroMVD to MicroMVDs for exchange requirements/Geometric detail MicroMVD over redirect: mistake)
The following MicroMVD vocabulary can be used to ensure that geometry is efficiently and appropriately stored in the IFC. Geometry has the single largest impact on file imports, exports, and coordination time.
Feature: Geometric detail To allow for the efficient transfer of geometry For any stakeholder using 3D geometry Geometry shall use the appropriate modeling techniques Scenario: Geometry must be efficiently modeled * All elements must be under "{number}" polygons
{number}
500 | Given that the vast majority of objects in AEC are box-like or cylindrical, most objects should not be above 500 polygons. For context, a single box is 6 polygons, and a cylinder, depending on its size, may be faceted into 18 polygons. However, many proprietary AEC applications have poor mesh support and may inefficiently translate geometry into a large number of polygons without the users intention. |
Software guides
Import | Export | ||||
ArchiCAD | N/A | ArchiCAD 23 | ||
BlenderBIM Add-on | N/A | v0.0.200829 | ||
FreeCAD | N/A | 0.19pre | ||
Revit | N/A | Revit 2020.2 IFC 8/5/2020 | Due to the lack of control in geometry export in Revit, and due to the serious bugs resulting in extreme filesize bloat during export, Revit is considered to have failed this MicroMVD in practice. | Refer to Revit and IFC Geometry |
Tekla |
