Building Energy Modeling (BEM)
Introduction
There is currently 2 BIM format related to energy modeling : gbXML and IFC (using IfcRelSpaceBoundary2ndLevel) Most energy analysis software reads gbXML. Some read IFC. Generating geometry for gbXML and IfcRelSpaceBoundary is quite similar. Information contained in both format is different. There are significant challenges (in 2022) with IFC and space boundaries, BuildingSMART International is working to improve the situation by improving the Information Delivery Manual (IDM) for Building Energy Modelling (BEM). The current status (in 2022) can be seen in a video from bS Virtual Summit Spring 2021 in the presentation BR5 - Jeffrey Ouellette - Building Energy Modelling (BEM).
Note to editors: Add a gbXML vs IFC features comparison
Modeling the building
FOSS authoring tools
BlenderBIM Add-on
BlenderBIM Add-on allows you to create, modify an IFC targeting energy analysis. You can either:
- Rework an IFC coming from another authoring tool. This is probably the most efficient workflow currently. It allows you to enhance your model and fixes common known issues incoming from popular authoring software.
- Create a model from scratch. You might want to take a look at topologic and related projects for more automation.
Energy specific geometry
Revit
Configuration
TODO
Known issues
IFC 2x3 and 4 :
IFC4 :
ArchiCAD
Configuration
Known issues
IFC 2x3 and 4 :
IFC4 :
Adaptation to local standards
- There is a discussion tag on our forum for Building Energy Modeling (BEM)
