IFC - Industry Foundation Classes/IFC concepts/IFC sequence concepts
- IfcWorkCalendar
- IfcWorkControl
- IfcWorkPlan
- IfcWorkSchedule
- IfcRelSequence
- IfcTask
- IfcTaskTime
- IfcLagTime
- IfcTaskType
Source: IfcWorkSchedule
A project may contain tasks
Source: IfcWorkPlan
A work plan may contain tasks
Source: IfcWorkPlan
A work calendar can be inherited through child tasks, procedures, and events
This same inheritance applies to procedures and events.
A task may contain subtasks
Source: IfcTask
Source: IfcTaskTime
Source: IfcTask
Source: IfcLagTime
Source: IfcProcess
Tasks may consume resources
A task consumes resources.
Source: IfcTask
Source: IfcTask
A task, event, or procedure may contain properties
A task, event, or procedure may contain properties. Typically this is used for risk assessment. For logistic tasks, it may also contain properties for packing instructions.
Source: IfcTask
Source: IfcTask
A project task may be based off a typical task type or template from a library of tasks
Source: IfcTask, IfcTaskType
A task type can nest a task type
Source: IfcTaskType
Source: IfcTaskType
A task type can nest a task, that is also typed
Source: IfcTaskType, IfcRelDefinesByObject
When a task type is used in a project, its child tasks are linked to the project tasks
