BlenderBIM Add-on/BlenderBIM Add-on code examples
< BlenderBIM Add-on
Revision as of 14:01, 27 July 2022 by Duncan (talk | contribs) (Duncan moved page BlenderBIM Add-on code examples to BlenderBIM Add-on/BlenderBIM Add-on code examples)
Run a script in blender from command line
Blender can run any Python script headlessly. This allows for a lot of automation, which may run on a scheduled time. On Linux or Mac, you can combine this with cron, or use scheduled tasks on Windows. For example, to run the script script.py, just execute:
blender -b -P script.py
Import an IFC
bpy.ops.import_ifc.bim(filepath='/path/to/your/file.ifc')
Export an IFC
bpy.ops.export_ifc.bim(filepath='/path/to/your/file.ifc')
To import an IFC:
import bpy
import logging
ifc_importer.execute()
To export an IFC:
import bpy
import logging
import blenderbim.bim.qto
ifc_exporter = blenderbim.bim.export_ifc.IfcExporter(settings, ifc_parser)
ifc_exporter.export(bpy.context.selected_objects)
Access IFC objects
Access multiple objects of specific criteria.
Access Elements
import bpy
walls = [obj for obj in bpy.context.scene.objects if obj.name.startswith("IfcWall")]
voids = [obj for obj in bpy.context.scene.objects if obj.name.startswith("IfcBuildingElementProxy/ProvisionForVoid")]
Read object IFC data
Examples affect active object only.
Element IFC Guid / GlobalId
import bpy
obj = bpy.context.active_object
IfcStore.get_file().by_id(obj.BIMObjectProperties.ifc_definition_id).GlobalId
Element Storey
import bpy
users_collections = bpy.context.active_object.users_collection
obj_storey = next(iter([coll for coll in users_collections if "IfcBuildingStorey" in coll.name]))
Manipulate object IFC data
PropertySet (Pset)
import bpy
# Adding a Pset
pset = bpy.context.active_object.BIMObjectProperties.psets.add()
pset.name = "MyPset"
# Adding a property of type string_value
prop = pset.properties.add()
prop.name = "MyProperty"
prop.string_value = "Hello World !"
Available value types
QuantityTakeOff (Qto)
import bpy
# Adding a Qto
qto = bpy.context.active_object.BIMObjectProperties.qtos.add()
qto.name = "MyQto"
prop = qto.properties.add()
prop.name = "MyQuantity"
prop.string_value = "10"
Manipulate material IFC data
PropertySet (Pset)
import bpy
# Adding a Pset
pset = bpy.context.object.active_material.BIMMaterialProperties.psets.add()
Clash Detection
Clash Detection on 2 sets of elements
Clash Detection on 3 cubes in two sets in this example:
import bpy
import collision
import numpy as np
import bmesh
import ifcclash
def get_collision_results(set_a=None, set_b=None):
    a_cm = collision.CollisionManager()
    b_cm = collision.CollisionManager()
    add_to_cm(a_cm, set_a)
    add_to_cm(b_cm, set_b)
    return a_cm.in_collision_other(b_cm, return_data=True)
def add_to_cm(cm, object_names):
    for object_name in object_names:
        name = object_name.name
        obj = bpy.data.objects[name]
        triangulated_mesh = triangulate_mesh(obj)
        mat = np.array(obj.matrix_world)
        mesh = ifcclash.Mesh()
        mesh.vertices = np.array([tuple(v.co) for v in triangulated_mesh.vertices])
        mesh.faces = np.array([tuple(p.vertices) for p in triangulated_mesh.polygons])
        cm.add_object(name, mesh, mat)
def triangulate_mesh(obj):
    mesh = obj.evaluated_get(bpy.context.evaluated_depsgraph_get()).to_mesh()
    bm = bmesh.new()
    bm.from_mesh(mesh)
    bmesh.ops.triangulate(bm, faces=bm.faces)
    bm.to_mesh(mesh)
    bm.free()
    del bm
    return mesh
set_a = [
    bpy.data.scenes['Scene'].objects['Cube'],
set_b = [
    bpy.data.scenes['Scene'].objects['Cube.001'],
    bpy.data.scenes['Scene'].objects['Cube.002'],
err, results = get_collision_results(set_a=set_a, set_b=set_b)
seen_pairs = set()
for result in results:
    result_pair = result.names
    result_names_str = str(result_pair)
    if result_names_str in seen_pairs:
        continue
    seen_pairs.add(str(result_pair))
    print(35 * "-")
    print(result_names_str)
