Tools
Blender (v2.8)
FreeCAD (v0.19)
Geometry scanning
- Import image set.
3D Mesh modeling
Importing the point clouds
Geometry modeling
- Install BlenderBIM Add-on
BIM modeling
Develop a BIM model with FreeCAD (using as reference the mesh or the IFC file from Blender). Once you got a good mesh volume of the building geometry, export a stl file or IFC file to FreeCAD to recreate the main walls, windows, doors and aditional architecture details of the building with the Arch Workbench. at the end of this workflow the idea is to save a FreeCAD file with only 3D models.
- Opt 1) Import a mesh file.
- Opt 2) Import a IFC file.
BIM modeling
- Open Draft Workbench.
2D CAD documentation
- Create a new FC file.
- Open Draft workbench.
- Save the file.
- Open TechDraw workbench
- Data/ Override Style = true
Export PDF files
