Tools
As a basic requirement for this tutorial, it is necessary to have a medium level of knowledge about these tools, used in this workflow.
Geometry scanning
- Import image set.
3D Mesh modeling
Importing the point clouds
Geometry modeling
- Install BlenderBIM Add-on
BIM modeling
Develop a BIM model with FreeCAD (using as reference the mesh or the IFC file from Blender). Once you got a good mesh volume of the building geometry, export a stl file or IFC file to FreeCAD to recreate the main walls, windows, doors and aditional architecture details of the building with the Arch Workbench.
- Opt 1) Import a mesh file.
- Opt 2) Import a IFC file.
BIM modeling
2D CAD documentation
2D documentation
