MicroMVDs for exchange requirements/Geolocation MicroMVD
Feature: Geolocation In order to query data in real world coordinates As a recipient expecting to integrate BIM and GIS datasets Geolocation data must be stored correctly in received files Scenario: Geometry is georeferenced to a coordinate reference system * There must be at least one "IfcSite" element * The project must have coordinate reference system data * The name of the CRS must be "{coordinate_reference_name}" * The description of the CRS must be "{value}" * The geodetic datum must be "{coordinate_reference_name}" * The vertical datum must be "{coordinate_reference_name}" * The map projection must be "{coordinate_reference_name}" * The map zone must be "{coordinate_reference_name}" * The map unit must be "{unit}" Scenario: Local coordinate systems are specified relative to a global system * The project must have coordinate transformations to convert from local to global coordinates * The eastings of the model must be offset by "{number}" to derive its global coordinates * The northings of the model must be offset by "{number}" to derive its global coordinates * The height of the model must be offset by "{number}" to derive its global coordinates * The model must be rotated clockwise by "{number}" to derive its global coordinates * The model must be scaled along the horizontal axis by "{number}" to derive its global coordinates Scenario: Global coordinates of the project origin are provided for convenient reference * The site "{guid}" has a longitude of "{longlat}" * The site "{guid}" has a latitude of "{longlat}" * The site "{guid}" has an elevation of "{number}"
{value}
{unit}
{number}
{longlat}
{guid}
Software guides
Import | Export | ||||
Tekla |
