MicroMVDs for exchange requirements/Project setup MicroMVD
Feature: Project setup In order to ensure quality of the digital built environment As a responsible digital citizen We expect compliant OpenBIM deliverables Scenario: Receiving a file * IFC data must use the "{schema}" schema Scenario: Exempt files * The IFC file "{file}" is exempt from being provided * No further requirements are specified because "{reason}" Scenario: Project metadata is organised and correct * The project must have an identifier of "{guid}" * The project name, code, or short identifier must be "{name}" * The project must have a longer form name of "{long_name}" * The project must be described as "{description}" * The project must be categorised under "{object_type}" * The project must contain information about the "{phase}" phase Scenario: Project geometry is stored * The project must contain 3D geometry representing the shape of objects
{file}
{schema}
{reason}
{guid}
{name}
{long_name}
{description}
{object_type}
{phase}
Software guides
Import | Export | ||||
BlenderBIM Add-on | v0.0.200722 | v0.0.200722 | ||
FreeCAD | 0.19pre | 0.19pre | GlobalId cannot be overridden during export. The project Name is not maintained during import.
Tekla |
