Revit setup for OpenBIM/Revit IFC geolocation
, E/W
, Elev
, and Angle to True North
and Survey Point
and the Survey Point
is the same.
IFC2X3 Geolocation
This Toposurface
Property Name | Required |
EPset_ProjectedCRS.Name
Yes |
EPset_ProjectedCRS.MapZone
EPset_ProjectedCRS.MapUnit
EPset_MapConversion.Eastings
Yes |
EPset_MapConversion.Northings
Yes |
Yes |
Yes |
Yes |
EPset_MapConversion.Scale
Yes |
IFC4 Geolocation
will be blank as it is not yet implemented in Revits exporter.
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
ProjectGlobalPositioning.Scale
Yes |
IFC2X3 and IFC4 geolocation patching
of the IfcSite
of the IfcBuilding
recipe:
is the Orthogonalheight
IFC2X3 and IFC4 geolocation reference information
To store the RefLatitude
and RefLongitude
correctly in the IfcSite
When the Search
attribute of the IfcSite
is the value you want to set.
or ElevationOfTerrain
attributes of the IfcBuilding
