Free software libraries for AEC software development
Entwine | Entwine is a data organization library for massive point clouds, designed to conquer datasets of trillions of points as well as desktop-scale point clouds. Entwine can index anything that is PDAL-readable, and can read/write to a variety of sources like S3 or Dropbox. Builds are completely lossless, so no points, metadata, or precision will be discarded even for terabyte-scale datasets. | LGPL-2.0 | |
IFC-Commenter | A simple script for creating a commented-out hiearchy in an IFC file. | MIT | |
LibreDWG | GNU LibreDWG is a free C library to handle DWG files. It aims to be a free replacement for the OpenDWG libraries. DWG is the native file format of AutoCAD and a number of other CAD packages. | GPL-3.0 |
Nucleus | ".NET Unifying Class Library for Engineering Utility Software. .Nucleus is an open-source .NET library intended as a generalisable base framework for the development of custom BIM and structural engineering workflow tools. It forms the core underlying class system of Salamander 3 and several internal Ramboll software projects." | MIT | |
OpenCascade | OpenCascade (Community Edition) is a C++ 3D modeling library. It can be used to develop CAD/CAM softwares, for instance FreeCAD or IfcOpenShell. | LGPL-2.1 | |
PDAL | PDAL (Point Data Abstraction Library) is a C++ BSD library for translating and manipulating point cloud data. In addition to the library code, PDAL provides a suite of command-line applications that users can conveniently use to process, filter, translate, and query point cloud data. | BSD |
pythonocc-core | Pythonocc provides 3D modeling and data exchange features. It is intended to CAD/PDM/PLM and BIM related development. | LGPL-3.0 | |
xeogl | xeogl is an open source JavaScript library from xeolabs for 3D model visualization on WebGL. It gives you tools to create interactive 3D worlds in your browser. Load models from formats like glTF or OBJ, or generate them programmatically. | MIT |
