IfcOpenShell code examples
Crash course
. The ifc
will be then used throughout.
import ifcopenshell
print(ifc.by_id(1))
value instead?
print(len(walls))
print(wall.id())
print(wall.GlobalId)
print(wall.Name)
import ifcopenshell.util
print(wall.IsDefinedBy)
print(ifc.get_inverse(wall))
print(ifc.traverse(wall))
s:
ifc = ifcopenshell.file()
ifc.create_entity('IfcWall')
data = {
'Name': 'Wall Name'
new_ifc = ifcopenshell.file()
new_ifc.add(wall)
ifc.remove(wall)
Geometry processing
import multiprocessing
import ifcopenshell
import ifcopenshell.geom
valid_file = iterator.initialize()
if valid_file:
while True:
shape = iterator.get()
if not iterator.next():
break
IFC Query Syntax
and if
statements, and for
module.
and .
selector = Selector()
symbol, for example:
Or by type using the *
symbol:
You can use AND
and OR
statements, using the &
and |
symbols respectively:
Exploring IFC schema
Get Schema :
import ifcopenshell
Explore class attributes :
ifc_pipe = schema.declaration_by_name("IfcPipeSegment")
ifc_pipe.all_attributes()
>>> (<attribute GlobalId: <type IfcGloballyUniqueId: <string>>>,
ifc_pipe.attribute_count()
>>> 9
ifc_pipe.attribute_by_index(0)
ifc_pipe.attribute_index("Description")
>>> 3
predefined_type = ifc_pipe.attribute_by_index(8)
predefined_type.name()
>>> 'PredefinedType'
predefined_type.optional()
>>> True
predefined_type.type_of_attribute()
predefined_type.type_of_attribute().declared_type().name()
>>> 'IfcPipeSegmentTypeEnum'
Get supertype :
ifc_pipe.supertype()
>>> <entity IfcFlowSegment>
Get subtypes :
super_type = ifc_pipe.supertype()
super_type.subtypes()
>>> (<entity IfcCableCarrierSegment>,
<entity IfcCableSegment>,
<entity IfcDuctSegment>,
<entity IfcPipeSegment>)
Samples from web
