Learning Material for Code Aster and Salome Meca
Revision as of 00:11, 15 May 2020 by Jesusbill (talk | contribs) (→‎Video Tutorials: minor fix)
A non-exhaustive list of learning material for whoever interested in using Code_Aster and Salome_Meca.
The BOOK
Beginning with code_aster - A practical introduction to finite element method using code_aster and Gmsh
This book by Jean-Pierre Aubry, one of the gurus and super-users of code_aster, is perhaps the must-read material for anyone wanting to start, especially structural engineers with focus on 1D [beams, columns, trusses, cables] and 2D [walls, slabs] analytical elements.
His pre- and post-processing workflow is based on Gmsh, outside thus the Salome_Meca ecosystem, and the material presented for creating the so-called "command file" that drives the code_aster analyses is invaluable.
Video Tutorials
Official Documentation and Code_Aster Forum
Code_Aster has perhaps one of the most extensive list of documentation and validation cases. The downside is that documentation is written in French and then machine-translated to English, which can be a bit clumsy at times. In any case, for a correct reference of the commands to be written in a command file I always recommend double-checking with the French version, other than that the English version is fine in most cases for reading.
  • Documentation for stable v14 version. Contains:
    • U(tilisation) documents that explain each available command
    • R(eference) documents that explain the theoretical basis of the code
    • V(alidation) documents that summarize the validation cases - along with an explicit list of all testcases by name
You can watch this video to see a bit about the documentation and how to access and run all testcases inside Salome_Meca. All testcases are also included in the installed folder of Salome_Meca [.../V201xxxxx/tools/Code_aster_xxxx/share/aster/tests]
Code_Aster in Italy - mostly for who speaks Italian
