List of known invalid IFC practices
Revision as of 01:25, 12 April 2021 by Moult (talk | contribs)
See also Category:IFC invalid practices
Autodesk Revit
Summary Last Verified
Using Open IFC, any objects using Tessellations are not supported. For example, if you export an IFC4 from ArchiCAD, unless you force it to use parametric solids, Revit will be unable to show the geometry in these IFCs. 2021-04-12
Bentley OpenBuildings Designer
IfcSurfaceStyleShading is still exported without an a Transparency attribute, even if an IFC4 export is done. This is technically correct if you check in a pre-addendum version of IFC4, but is not useful to users or updated IFC4 parsers. 2019-05-23
