MicroMVDs for exchange requirements/Geolocation MicroMVD
Feature: Geolocation In order to query data in real world coordinates As a recipient expecting to integrate BIM and GIS datasets Geolocation data must be stored correctly in received files Scenario: Receiving a file * The IFC file "{file}" must be provided * IFC data must use the {schema} schema Scenario: Geometry is georeferenced to a coordinate reference system * There must be at least one IfcSite element * The project must have coordinate reference system data * The name of the CRS must be {coordinate_reference_name} * The description of the CRS must be {value} * The geodetic datum must be {coordinate_reference_name} * The vertical datum must be {coordinate_reference_name} * The map projection must be {coordinate_reference_name} * The map zone must be {coordinate_reference_name} * The map unit must be {unit} Scenario: Local coordinate systems are specified relative to a global system * The project must have coordinate transformations to convert from local to global coordinates * The eastings of the model must be offset by {number} to derive its global coordinates * The northings of the model must be offset by {number} to derive its global coordinates * The height of the model must be offset by {number} to derive its global coordinates * The model must be rotated clockwise by {number} to derive its global coordinates * The model must be scaled along the horizontal axis by {number} to derive its global coordinates Scenario: Global coordinates of the project origin are provided for convenient reference * The site {guid} has a longitude of {longlat} * The site {guid} has a latitude of {longlat} * The site {guid} has an elevation of {number}
{file}
{schema}
{value}
{unit}
{number}
{longlat}
{guid}
Software guides
Import | Export | ||||
ArchiCAD | ArchiCAD 23 | You cannot export a unit for the coordinate reference system. Also, when exporting to IFC, it may apply the true north rotation, but retain the rotation in the geolocation properties, thus effectively defining the rotation twice. This leads to an incorrectly geolocated model which needs to be patched. | ||
FreeCAD | ||||
Tekla |
