OpenStudio/Video Tutorials
< OpenStudio
Revision as of 12:56, 26 April 2025 by IanVG (talk | contribs)
Helix Energy Partners
Free Helix Energy Partners videos available on Youtube. Complete playlist is here.
Caption text
Name of Video OpenStudio Version Date Published Subject
Introduction to OpenStudio and EnergyPlus - 2020.02.12 0-Meta
Introduction to OpenStudio and EnergyPlus - Why? - 2023.04.08 0-Meta
Building Energy Modeling in OpenStudio - Install the Software - 2025.03.18 0-Meta
Building Energy Modeling in Open Studio - Importing Library Files - 2020.02.14 0-Meta
Building Energy Modeling in OpenStudio - Create Geometry - 2020.02.17 6-Geometry
Building Energy Modeling in OpenStudio - Add Thermal Zones and Subsurfaces - 2020.02.17 9-Thermal Zones
Building Energy Modeling in OpenStudio - Site Tab - 2020.02.18 1-Site
Building Energy Modeling in OpenStudio - Schedules Tab - 2020.02.18 2-Schedules
Building Energy Modeling in OpenStudio - Construction Materials - 2020.02.24 3-Constructions
Building Energy Modeling in OpenStudio - Buildings Loads - 2020.02.24 4-Loads
Building Energy Modeling in OpenStudio - Space Types - 2020.02.24 5-Space Types
Building Energy Modeling in OpenStudio - Geometry Tab - 2020.02.27 6-Geometry
Building Energy Modeling in OpenStudio - Facility Tab - 2020.02.27 7-Facility
Building Energy Modeling in OpenStudio - Spaces Tab - 2020.02.27 8-Spaces
Building Energy Modeling in OpenStudio - Thermal Zones Tab - 2020.03.02 9-Thermal Zones
Building Energy Modeling in OpenStudio - Troubleshooting - 2020.03.03 0-Meta
Building Energy Modeling in OpenStudio - Results Summary - 2020.03.03 15-Results Summary
Building Energy Modeling in OpenStudio - Add Hot Water System - 2020.03.04 10-HVAC Zones
Building Energy Modeling in OpenStudio - Add HVAC-1 - 2020.03.05 10-HVAC Zones
Building Energy Modeling in OpenStudio - Add HVAC-2 - 2020.03.05 10-HVAC Zones
Building Energy Modeling in OpenStudio - Add DOAS System - 2020.03.08 10-HVAC Zones
Building Energy Modeling in OpenStudio - Data Viewer - 2020.03.10 15-Results Summary
Building Energy Modeling in OpenStudio - Exhaust MUA - 2020.03.11 10-HVAC Zones
Building Energy Modeling in OpenStudio - Transfer Air - 2020.03.30 -
Building Energy Modeling in OpenStudio - SketchUp-1 - 2020.07.02 6-Geometry
Building Energy Modeling in OpenStudio - SketchUp-2 - 2021.03.02 6-Geometry
Building Energy Modeling in OpenStudio - Add Heat Pump Hot Water System - 2024.12.08 10-HVAC Zones
NRELOpenStudio
  1. OpenStudio 0.8 Basic Workflow Guide (Introduction & Interactive PDF)
    • This video gives you an introduction to the interactive PDF for OpenStudio 0.8.0
  2. OpenStudio 0.8 Basic Workflow Guide (SketchUp Plugin - Building Envelope)
    • This video shows you how to choose a template, create your building envelope, add fenestration, and to set boundary conditions and thermal connections between spaces. This video uses the OpenStudio SketchUp plugin.
  3. OpenStudio 0.8 Basic Workflow Guide (SketchUp Plugin - Space Types and Thermal Zones)
    • This video shows you how to assign space types, thermal zones, and thermostats to the spaces in your model. This video uses the OpenStudio SketchUp plugin.
  4. OpenStudio 0.8 Basic Workflow Guide (Site, Facility, and Basic Run)
    • This video goes into the OpenStudio application, adds weather data, shows the outline view in the facility tab and then runs a simulation with ideal air loads.
  5. OpenStudio 0.8 Basic Workflow Guide (Space Types, Internal Loads, and Schedules)
    • This video demonstrates how you can inspect, alter, and apply resource objects in OpenStudio.
  6. OpenStudio 0.9 New Features (Constructions, Materials and the Building Component Library)
    • This video demonstrates the new construction and material editor in OpenStudio 0.9.0 as well as the integrated Building Component Library functionality.
  7. OpenStudio 0.8 Basic Workflow Guide (HVAC - Zone Equipment, Air Loops, and Plant Loops)
    • This video shows you how to add HVAC systems, it introduces the variable and scripts tab, and then runs a simulation with the resulting model.
  8. OpenStudio 0.9 New Features (Service Hot Water)
    • This video shows you how to create models using service hot water. This includes hot water heaters, water use connections, water use equipment, and other associated objects.
OpenStudio Coalition
