OpenStudio/Video Tutorials
Helix Energy Partners
Free Helix Energy Partners videos available on Youtube. Complete playlist is here.
NRELOpenStudio
- OpenStudio 0.8 Basic Workflow Guide (Introduction & Interactive PDF)
- This video gives you an introduction to the interactive PDF for OpenStudio 0.8.0
- OpenStudio 0.8 Basic Workflow Guide (SketchUp Plugin - Building Envelope)
- This video shows you how to choose a template, create your building envelope, add fenestration, and to set boundary conditions and thermal connections between spaces. This video uses the OpenStudio SketchUp plugin.
- OpenStudio 0.8 Basic Workflow Guide (SketchUp Plugin - Space Types and Thermal Zones)
- This video shows you how to assign space types, thermal zones, and thermostats to the spaces in your model. This video uses the OpenStudio SketchUp plugin.
- OpenStudio 0.8 Basic Workflow Guide (Site, Facility, and Basic Run)
- This video goes into the OpenStudio application, adds weather data, shows the outline view in the facility tab and then runs a simulation with ideal air loads.
- OpenStudio 0.8 Basic Workflow Guide (Space Types, Internal Loads, and Schedules)
- This video demonstrates how you can inspect, alter, and apply resource objects in OpenStudio.
- OpenStudio 0.9 New Features (Constructions, Materials and the Building Component Library)
- This video demonstrates the new construction and material editor in OpenStudio 0.9.0 as well as the integrated Building Component Library functionality.
- OpenStudio 0.8 Basic Workflow Guide (HVAC - Zone Equipment, Air Loops, and Plant Loops)
- This video shows you how to add HVAC systems, it introduces the variable and scripts tab, and then runs a simulation with the resulting model.
- OpenStudio 0.9 New Features (Service Hot Water)
- This video shows you how to create models using service hot water. This includes hot water heaters, water use connections, water use equipment, and other associated objects.
OpenStudio Coalition
- What is OpenStudio? - Introduction video
- Using the Parametric Analysis Tool PAT with the OpenStudio App, Part 1
- Using the Parametric Analysis Tool PAT with the OpenStudio App, Part 2
- Creating Geometry in the OpenStudio App with Floorspace.js
- Energy Modeling 101 OpenStudio Application A-Z
