< BlenderBIM Add-on
Revision as of 06:07, 14 April 2025 by Steverugi (talk | contribs) (→‎Create a Schedule of Rates)
W.I.P. Demonstrations[edit]
Main Topics[edit]
Video Demo[edit]
Sample Files[edit]
Project setup[edit]
Create New Project
Open an Existing IFC Project
Create a Cost Schedule[edit]
Create a New IfcCostSchedule
Edit Cost Schedule Properties
  • Name,
  • Description,
  • ObjectType,
  • Identification,
  • PredefinedType,
  • Submitted On,
  • Update Date,
Note:
The purpose of the Schedule of Rates is to provide a Cost Schedule limited to the Cost Value of a Cost Item without quantities
Create Cost Schedule of Rates
Create Cost Item in a Schedule of Rates
Create Cost Items[edit]
Add Summary Cost
Cost Item entities
Cost Item Edit Menu
  2. Sorting order
  3. Quantity
  4. Value
  5. Edit attributes
Cost Item Hierarchy
Cost Items Nested Structure
Add Cost Item Values[edit]
  1. Manually
edit cost item
Edit cost value
  1. From a Schedule of Rates
  • select the rate
edit quantity
quantity edit 2
edit quantity step 3
Insert Content Here
Useful Tools[edit]
Insert Content Here
Quantity Take off Tools[edit]
    1. Manual quantities
    2. Automatic quantities
    3. Derive formwork areas
Sample Files[edit]
- .ifc template for costing
