W.I.P. Demonstrations
Live Session 1 15/05/2021
Main Topics
Video Demo
Sample Files
Project setup
Create a Cost Schedule
Edit Cost Schedule attributes
- Name,
- Description,
- ObjectType,
- Identification,
- PredefinedType,
- Submitted On,
- Update Date,
Note:
Create a Schedule of Rates
The purpose of the Schedule of Rates is to provide a Cost Schedule limited to the Cost Value of a Cost Item without quantities
Create Cost Items
- Sorting order
- Quantity
- Value
- Edit attributes
Add Cost Item Values
- Manually
- From a Schedule of Rates
- select the rate
Add Cost Item Quantities
Insert Content Here
Calculate Cost Item Totals
Useful Tools
Insert Content Here
Quantity Take off Tools
- Manual quantities
- Automatic quantities
- Derive formwork areas
Creating Project Libraries
Sample Files
- .ifc template for costing
