Main functions:
Main functions:
Main Features:
Main Features:
Main Features:
EXPLORING AN IFC[edit]
BASIC DESIGN TOOLS[edit]
IfcElementType
IfcElement
Summary in a Table
Practical Example
Modifying data[edit]
Modifying Position[edit]
Modifying Geometry[edit]
What are Psets?
Types of Property Sets in IFC
- Standardization: They ensure that all projects follow the same logic and structure, promoting consistency across designs.
- Ease of Analysis: They allow for efficient filtering and analysis of specific elements. Without custom Psets, navigating through data would be like searching for a needle in a haystack.
Adding Psets in Bulk[edit]
3. From here, you can:
Important Notes[edit]
- Editing Properties: When editing properties, the object will only retain the properties you list. If you include only one property, the rest will be removed. Ensure you include all necessary properties to avoid data loss.
- Renaming vs. Editing: Renaming only changes the name of the property. To edit values, use the Edit function. Properly managing your Psets will ensure the accuracy and integrity of your model.
IFC MANAGEMENT[edit]
1. Containers:
2. In Zone 3, you can:
Federating and Merging[edit]
