The OpenBIM Pledge
Revision as of 01:49, 26 March 2025 by 1.40.5.139 (talk) (→‎Tier 4)
Tier 0
Tier 1
Tier 2
Tier 3
Tier 4
  • I will not require any properties that can be derived from counting classes (e.g. total building storeys). This removes duplication of data, possibility of mistakes.
  • I will not require any properties on an occurrence (e.g. room number) that can instead by stored on the relating container (e.g. space, storey, etc) or relating system (e.g. distribution system, circuit). This removes duplication of data and is a good first step away from dumb properties and towards intelligent, related semantic objects.
Tier 5
... more to come.
Tier 6
  • Smart building schemas such as Brickschema must be derived from IFC. This is the first step towards connecting to smart building sensors, events, and procedures.
... more to come.
