The OpenBIM Pledge
Revision as of 21:55, 25 March 2025 by 1.40.5.139 (talk)
This pledge is inspired by the pledge signed by browser vendors who stopped fighting and instead worked together to implement standards-compliant web technologies. This is a technical document, aimed at a technical audience of digital engineers. Signing this document is entirely voluntary.
Tier 0
Tier 1
  • If I require for any simple properties attached to objects, I will specify and check for a property name, property set name and IFC data type (e.g. IfcLabel, IfcIdentifier, IfcPositiveLengthMeasure) of the data.
Tier 2
  • All IfcProduct and IfcTypeProducts must be assigned to the correct IFC class. This means that regardless of people's favourite classification flavour of the day, there is a fallback "broad" classification that anybody can use for any process. This does not stop you from using additional classifications on top of IFC's built-in classes.
  • If I require properties or quantities that already exists as part of a buildingSMART standardised template (i.e. those prefixed with Pset or Qto), I will use that instead of reinventing my own.
  • I will provide an IDS for simple property requirements so that audits are standardised and there are no ambiguities are nasty surprises.
Tier 3
  • If I additionally want my own classification system on top, it must be stored as a classification reference in an IfcClassification, not as a property. This means that filtering of classifiations can actually benefit from understanding the hierarchical nature of classifications.
  • If I want quantity data, it must be stored as a quantity set, not as a property. This allows us to separate calculable or geometry-derived data from semantic data so we can recalculate and check quantities properly.
Tier 4
... more to come.
