BONSAI INTERFACE OVERVIEW
EXPLORING AN IFC
DESIGN AND EDITING OF IFC
BASIC DESIGN TOOLS
IfcElementType
IfcElement
Summary in a Table
Practical Example
Creating Generic Elements
Modifying data
Modifying Position
Modifying Geometry
Option 1: Creating Voids
Option 2: Boolean Method
What are Psets?
Types of Property Sets in IFC
Adding Psets Individually
Adding Psets in Bulk
3. From here, you can:
Important Notes
IFC MANAGEMENT
(Re)Organizing the Model
1. Containers:
2. In Zone 3, you can:
Filtering Elements
Filtering Information
As mentioned earlier, one of the main advantages of a BIM model is the vast amount of information it contains. To efficiently locate specific information, it is essential to use filters, similar to how you would in a large Excel spreadsheet.
Bonsai offers advanced filtering tools. To access these features, follow these steps:
Accessing Filters
1. Go to the Project Overview tab.
2. Open the Grouping and Filtering dropdown. Here, you will find various filtering options.
Filtering Options
1. Search
  • This option allows you to search for elements based on their classification, material, Psets, or other criteria.
  • Usage examples:
 Search for elements by their IFC classification (e.g., IfcWall or IfcWindow).
 Filter elements based on custom Psets you have created.
2. Filter Selection
This tool allows you to apply filters directly to the current selection. It is intuitive and does not require extensive explanation, but we encourage you to explore it to discover all its functionalities.
3. Color By Property This is one of the most visual and useful tools. It allows you to classify model elements by color based on their properties. Usage example: Assign different colors to elements based on their material, IFC classification type, or custom Psets. This functionality is particularly useful for quickly identifying patterns or anomalies in the model.
Recommendations for Using Filters Use custom Psets: Creating specific Psets for your projects will allow you to filter and organize information more efficiently. Maintain correct syntax: When using advanced filters, ensure you follow the recommended syntax to avoid errors. Experiment with Color By Property: This tool is not only visually appealing but can also significantly enhance your ability to analyze and present the model.
Federating and Merging
Extracting Data and Elements
