BONSAI INTERFACE OVERVIEW
EXPLORING AN IFC
DESIGN AND EDITING OF IFC
BASIC DESIGN TOOLS
IfcElementType
IfcElement
Summary in a Table
Practical Example
Creating Generic Elements
Modifying data
Modifying Position
Modifying Geometry
Option 1: Creating Voids
Option 2: Boolean Method
What are Psets?
Types of Property Sets in IFC
Additional Resources For further guidance, refer to this tutorial: [YouTube](https://www.youtube.com).
IFC MANAGEMENT
(Re)Organizing the Model
Filtering Elements
Federating and Merging
Extracting Data and Elements
