BONSAI INTERFACE OVERVIEW
Main functions:
Main functions:
Main Features:
Main Features:
Main Features:
EXPLORING AN IFC
DESIGN AND EDITING OF IFC
BASIC DESIGN TOOLS
IfcElementType
IfcElement
Summary in a Table
Practical Example
Creating Generic Elements
Modifying data
Modifying Position
Modifying Geometry
Option 1: Creating Voids
(Managing Psets in IFC)
IFC MANAGEMENT
(Re)Organizing the Model
Filtering Elements
Federating and Merging
Extracting Data and Elements
