Bonsai Interface Overview
Main functions:
Main functions:
Main Features:
Main Features:
Main Features:
Opening and exploring an IFC model
DESIGN AND EDITING OF IFC
Basic design tools
(Explanation of basic design tools)
Adding data
(Managing Psets in IFC)
IFC MANAGEMENT
(Re)Organizing the Model
Filtering Elements
Federating and Merging
Extracting Data and Elements
