W.I.P. Demonstrations
Live Session 1 15/05/2021
Main Topics
Video Demo
Sample Files
Project setup
Creating a Cost Schedule
- Name,
- Description,
- ObjectType,
- Identification,
- PredefinedType,
- Submitted On,
- Update Date,
Note:
Creating Cost Items
- Sorting order
- Quantity
- Value
- Edit attributes
Adding Cost Item Values
Insert Content Here
Creating Cost Item Quantities
Insert Content Here
Insert Content Here
Insert Content Here
Caclulating Cost Item Totals
Useful Tools
Insert Content Here
Quantity Take off Tools
- Derive formwork areas
Creating Project Libraries
Sample Files
- .ifc template for costing
