BlenderBIM Add-on/Shortcuts
Blender
  • shift + tab -> toggle snap
  • h -> hide selected objects
  • alt + h -> unhide objects
  • tab -> toggle [EDITMODE] vs. [OBJECTMODE] modes
BlenderBIM
  • ctrl + s -> save file
  • ctrl + o -> open file
