BlenderBIM Add-on/Shortcuts
Blender
- ctrl + alt + q -> (quad view) split the 3D Viewport into four views: three orthographic side views and one user perspective view. Press again to return to normal.
- shift + tab -> toggle snap
- h -> hide selected objects
- alt + h -> unhide objects
- ctrl + F2 -> pop-up menu to batch rename multiple objects
- tab -> toggle [EDITMODE] vs. [OBJECTMODE] modes
BlenderBIM
- ctrl + s -> save file
- ctrl + o -> open file
- shift + ctrl + d ->duplicate aggregate https://github.com/IfcOpenShell/IfcOpenShell/pull/3328
- shift + e -> [ANNOTATION TOOL] pop-up menu to edit text
