FreeCAD/Page layouts with TechDraw WB
< FreeCAD
Revision as of 15:00, 5 November 2023 by Bitacovir (talk | contribs) (Undo revision 5633 by Bitacovir (talk))
FreeCAD files[edit]
Project Description
Freecad TechDrawWB.png File:FC Bathroom.fcstd
FreeCAD file with a 3D model of bathroom and 3 possible layouts made with TechDraw WB
2DDrawingFC01.png File:FreeCAD House RenovationBlueprints.fcstd
FreeCAD file with layouts of a house renovation made with TechDraw WB
FC FurnitureCompound.png File:FurnitureCompound.fcstd
FreeCAD file with a 3D object (furniture) linked to a 2D projection. You can turn on/off the 3D model and keep visible the 2D projection in the tridimensional space or in the TechDraw page. This workflow uses App Link objects. See below a description of this workflow.
Freecad dLabel.png File:Dlabel for Shape2d.fcstd
FreeCAD file with a window object 2D projection, linked to a Draft label. If you change the information or model of the window 3D object, the label in the 2D projection will update automatically.
FreecadDlabel.png File:Dlabel on Shape2d V2.fcstd
New version of a FreeCAD file with a window object 2D projection, linked to a Draft label. If you change the information or model of the window 3D object, the label in the 2D projection will update automatically.
Workflow tips[edit]
Yorik's workflow.[edit]
  1. Model your building using BIM or any other FreeCAD tools
  2. Use Building parts for your levels (not mandatory, but they carry an automatic, built-in section plane)
  3. Place Section planes where you want sections and elevations (and plans if you didn't use Building parts)
  4. Create Shape 2D views from your Building parts and section planes
  5. Create other Shape 2D views for views that cut through your model, and set them in Cut Faces mode. That way, you can give a different aspect to viewed and cut geometrty
  6. Annotate these views with texts, dimensions, symbols, hatches...
  7. Put everything related to one view (Shape 2D views, annotations,...) into one same group or Building part
  8. On a TechDraw page, create a TechDraw view from that group or Building part.
Recommended links between TechDraw Views and 2D objects
use TD InsertView for Shape2DView Plans, Sections Allow to apply hatches on plans and sections areas.
use TD InsertView for Draft lines Simple lines and symbols Allow to work with different line widths.
use TD DraftView for Draft Layers Dimensions, texts, lines Allow to apply line styles and other properties on group of draft objects
use TD DraftView for Draft objects Simple lines and symbols Allow to apply line styles and other properties on individual objects
use TD ArchView for Arch SectionPlane Sections, dimensions, Lines and symbols Allow to apply line widths and other properties on cut lines.
  1. Create a file with a piece of furniture.
  2. Make a 2D view from the top using Shape 2D View and put it all in a Link Group.
  3. Link the furniture to the main file where you are doing the project.
  4. In this example I created 6 elements of the furniture using the Element Count option.
  5. Then select all the 2D drawings of each element and create sub-links.
  6. Create a 2D layer and put all the sub-links into it.
  7. This enables us to show the 2D drawing and 3D model at different times, which is very practical later on in combination with Working Plane View to create 2D plans.
  8. When one of the elements is moved, the 2D drawing is moved together with it.
  9. Insert a TD DraftView in a TechDraw page. You can move the sub-links object to arrange the furniture layout. If you include a couple of lines as "mayor frame" in the layer, the TD_DraftView will keep the same position in the TD page.
External references[edit]
Icon FreeCAD.png This page is FreeCAD documentation. Full documentation is available at the FreeCAD documentation wiki. All articles in the OSArch wiki related to FreeCAD can be seen in the FreeCAD Category
