BlenderBIM Add-on/IFC Patch Recipes
< BlenderBIM Add-on
Revision as of 21:36, 30 August 2022 by 47.12.111.147 (talk)
Code for IFC Patch Recipes in located here.
For Windows use /
, for all other platforms use \
in the path
MergeProject
OffsetObjectPlacements
The arguments for OffsetObjectPlacements are a list of numbers. If you specify 3 numbers [X,Y,Z], the coordinates will be offset by X, Y, Z. If you specify 4 numbers [X,Y,Z,Az], it will be offset by X, Y, Z and rotated along the Z axis by Az. If you specify 6 numbers [X,Y,Z,Ax,Ay,Az] it will translate along all three axes and also rotate along all three axes. -source
RecycleNonRootedElements
Consolidates redundant non-rooted entities, like the following example, down to one entity.
#45=IFCOWNERHISTORY(#9,#8,.READWRITE.,.MODIFIED.,1629040293,#9,#8,1629040293);
#52=IFCOWNERHISTORY(#9,#8,.READWRITE.,.MODIFIED.,1629040293,#9,#8,1629040293);
