MicroMVDs for exchange requirements/Element classes MicroMVD
Revision as of 11:22, 28 July 2022 by Duncan (talk | contribs) (Duncan moved page MicroMVDs for exchange requirements/MicroMVDs for exchange requirements/Element classes MicroMVD to MicroMVDs for exchange requirements/Element classes MicroMVD over redirect: mistake)
{guid}
{ifc_class}
{predefined_type}
{reason}
Software guides[edit]
Import | Export | ||||
Tekla |
