MicroMVDs for exchange requirements/Classification MicroMVD
Revision as of 11:22, 28 July 2022 by Duncan (talk | contribs) (Duncan moved page MicroMVDs for exchange requirements/MicroMVDs for exchange requirements/Classification MicroMVD to MicroMVDs for exchange requirements/Classification MicroMVD over redirect: mistake)
For guidance on what values should be filled in for standardised classification systems, refer to IFC classifications.
Feature: Classification For BIM objects to be filtered and categorised in facility management system As someone who needs to catalogue BIM data in a structured and organised manner Classification systems data must be assigned to each relevant element Scenario: The appropriate classification systems are referenced in the model * The classification "{name}" must be used * The classification "{name}" is published by "{source}" * The classification "{name}" is the edition "{edition}" on "{edition_date}" * The classification "{name}" has the description "{description}" * The classification "{name}" is referenced by the website "{location}" * The classification "{name}" has a hierarchy denoted by the tokens "{tokens}" Scenario: The relevant elements are assigned to the classification system * The element "{guid}" is classified as a "{identification}" with name "{reference_name}"
Note that for IFC2X3, the following rules will not apply, as the data cannot be stored in IFC2X3.
{guid}
{name}
Uniclass 2015 | The name of the classification system, taken from the standard list if it exists. |
{source}
RIBA Enterprises Ltd | The source or publisher of the classification system, taken from the standard list if it exists. |
{edition}
January 2020 | Classifications are often revised, this refers to the standard edition name, taken from the standard list if it exists. |
{edition_date}
2020-02-07 | A YYYY-MM-DD value of when the edition was released. |
{description}
Uniclass 2015 is a unified classification for the UK industry covering all construction sectors. | The official description of the classification system, taken from the standard list if it exists. |
{location}
https://toolkit.thenbs.com/articles/classification | The official website to refer to the classification online, taken from the standard list if it exists. |
{tokens}
["_"] | A JSON list of of all of the separating tokens which denote hierarchy in the classification system, taken from the standard list if it exists. |
{identification}
Co_20_10_60 | A single classification reference identification for the particular classification system, taken from the standard list if it exists. |
{reference_name}
Governmental complexes | A single classification reference name for the particular classification system, taken from the standard list if it exists. |
Software guides[edit]
Import | Export | ||||
ArchiCAD | ArchiCAD 23 | Some work is required to set up the export, but it is possible. However, the description, location, and reference tokens for the IfcClassification cannot be exported. It should also be noted that the Graphisoft classification XMLs tend to store the location data in the source field, which is incorrect.
FreeCAD | ||||
Revit | ||||
Tekla |
