MicroMVDs for exchange requirements/COBie MicroMVD
Revision as of 11:21, 28 July 2022 by Duncan (talk | contribs) (Duncan moved page MicroMVDs for exchange requirements/COBie MicroMVD to MicroMVDs for exchange requirements/MicroMVDs for exchange requirements/COBie MicroMVD)
Note that the vocabulary is not currently exhaustive.
Given the IFC file "{file}"
