MicroMVDs for exchange requirements/Element classes MicroMVD
Revision as of 11:20, 28 July 2022 by Duncan (talk | contribs) (Duncan moved page Element classes MicroMVD to MicroMVDs for exchange requirements/Element classes MicroMVD)
{guid}
{ifc_class}
{predefined_type}
{reason}
Software guides
Import | Export | ||||
Tekla |
