Drawing (DWG)
Revision as of 09:55, 23 January 2022 by Duncan (talk | contribs) (→‎See also)
The Drawing (DWG) file format developed by Autodesk is a proprietary file format and the native file format for a number of proprietary CAD systems. The Drawing Exchange Format (DXF) is usually a better alternative for free software as it has better support for virtually the same content.
DWG in FOSS Software
There have been two efforts at making a free software library for reading/writing DWG.
  • libdxfrw which is the default DXF/DWG library for LibreCAD (versions 2 & 3)
  • LibreDWG which is more advanced but in beta state
Free software known to have some support for DWG
  • FreeCAD uses LibreDWG from version 0.19 for Linux builds and Conda Windows builds. Otherwise check the FreeCAD documentation or ask in our forum.
  • GauchoCAD uses LibreDWG but is currently alpha software with no released packages
  • LibreCAD has basic DWG support using the libdxfrw library
  • SolveSpace can import DXF and DWG and export 2D sketches and 3D wireframes as DXF using the libdxfrw library. Moving to LibreDWG is under discussion.
  • QCAD has a commercial version which adds DWG support using the non-free ODA Teigha Library.
Current status of LibreDWG
Please test and report bugs.
There is currently focus on gambas bindings (that's the free GNU VBA variant) for GauchoCAD and C++ bindings for SolveSpace. Perl and python bindings are ready but unused.
Current limitations:
  • Not feature parity with Open_Design_Alliance_(ODA)
  • Many basic dynamic blocks and parametrics are done but it's still a work in progress.
  • DWG write support for 2004-2018 is about 80% done, still some bugs.
  • Creating 3dsolids from scratch, writing acis data is also not yet good enough.
  • The objects and fields are all done, but it's undocumented and unstable.
  • lisp bindings, like for guile would be nice, but low priority (no one has asked for it)
External Resources
