Drawing (DWG)
The Drawing (DWG) file format developed by Autodesk is a proprietary file format and the native file format for a number of proprietary CAD systems. The Drawing Exchange Format (DXF) is usually a better alternative for free software as it has better support for virtually the same content.
DWG in FOSS Software
Current status
(Heavily inspired by a post by Reini Urban to the LibreDWG discussion list)
There have been two efforts at making a free software library for reading/writing DWG.
Free software known to have some support for DWG:
- FreeCAD from version 0.19. You can read the discussion in Let's talk about libredwg support.
- GauchoCAD currently alpha software with no released packages
Generally LibreDWG is stable for the most common entities and objects for DWG and DXF, plus hundreds more. It can write DWG r2000 already, plus all DXF versions. DWG write support for 2004-2018 is about 80% done. Please report bugs].
For the more technically minded see the link to the original thread.
There is currently focus on gambas bindings (that's the free GNU VBA variant) for GauchoCAD and C++ bindings for SolveSpace. Perl and python bindings are ready but unused.
Current limitations:
- Not feature parity with Drawings SDK
- Many basic dynamic blocks and parametrics are done but it's still a work in progress.
- DWG write support for 2004-2018 is about 80% done, still some bugs.
- Creating 3dsolids from scratch, writing acis data is also not yet good enough.
- The objects and fields are all done, but it's undocumented and unstable.
- lisp bindings, like for guile would be nice, but low priority (no one has asked for it)
- Drawing Exchange Format (DXF)
- Open_Design_Alliance_(ODA)
- Autodesk
- FreeCAD
- GauchoCAD
- Getting started with 2D CAD drafting
External Resources
- The Open Design Alliance has a freely available proprietary ODA File Converter for converting between different versions of .dwg and .dxf
- DWG at Wikipedia gives background on the way Autodesk has pursued anyone trying to achieve compatability.
