MicroMVDs for exchange requirements/Element classes MicroMVD
Feature: Element classes In order to correctly identify objects As any interested stakeholder filtering objects for a particular purpose All IFC elements must belong to the appropriate IFC class Scenario: Receiving a file * The IFC file "{file}" must be provided * IFC data must use the {schema} schema Scenario: Ensure all IFC type elements use the correct IFC class * The element {guid} is an {ifc_class} * The element {guid} is an {ifc_class} only * The element {guid} is further defined as a {predefined_type} * The element {guid} should not exist because {reason}
{file}
{schema}
{guid}
{ifc_class}
{predefined_type}
{reason}
Software guides
Import | Export | ||||
Tekla |
